Topic: Phrase sync
Hi, I use vdj latest version and cntroller pioneer ddj1000.
Is there a possibility to sync the phrase (beat is allready ) automatic with the other deck using the sync knob on my controller?
geposted Sun 23 Jan 22 @ 10:07 am
Thats the thing sync doesnt do...
geposted Sun 23 Jan 22 @ 1:18 pm
Try mapping phrase_sync to a custom button, and test if that does what you want
It was improved recently (from the release notes: "phrase_sync works when one deck has double bpm of the other"), so you should probably make sure you have the latest version)
geposted Sun 23 Jan 22 @ 3:04 pm
Klaus thank you, but double bpm? i dont understand that, is saw it in the chancelog .. my wish is phrase sync bij near beat to the second deck
i have the latest version 6800...
geposted Mon 24 Jan 22 @ 6:28 pm
Looking well
geposted Mon 24 Jan 22 @ 6:47 pm
The script phrase_sync, has always worked flawlessly, for phrase syncing 2 decks with same BPM.
In the latest update, phrase_sync was updated to allow for better phrase syncing between decks; one deck, say at 70 BPM and the other at 140 BPMs.
geposted Mon 24 Jan 22 @ 10:00 pm
