Forum: Addons
Topic: Numark Mixstream Pro Screen
geposted Tue 26 Apr 22 @ 4:18 pm
Hello, I have downloaded the MixStream Pro skin to my PC, but it is not showing up in available options to use or apply this skin.
geposted Sun 08 May 22 @ 5:08 pm
It will be used automatically when you connect the Numark Mixstream Pro controller.
geposted Sun 08 May 22 @ 5:46 pm
Even after I connected it, it still didnt work for me
geposted Tue 17 May 22 @ 9:50 pm
geposted Wed 18 May 22 @ 4:48 am
bonjour je cherche skin Numark NV svp
geposted Sat 11 Jun 22 @ 11:31 am
You can use any skin. The software does not need to look like the hardware in order to work.
geposted Sat 11 Jun 22 @ 2:07 pm
bad skins no work
geposted Mon 25 Jul 22 @ 8:35 am
Bigbutler wrote :
bad skins no work
It's not for the VDJ software - its for the screen on the Mixstream Pro
geposted Mon 25 Jul 22 @ 12:38 pm
RemsoyePRO InfinityMember since 2016
Salut, Tu as trouvé depuis ?
geposted Tue 13 Sep 22 @ 6:45 pm
I have the same issue. Extensions indicate that I have the skin installed. It does not appear when I connect my controller. It is also not in the list of installed skins.
geposted Sun 18 Sep 22 @ 12:00 pm
It's not supposed to be visible there, as it's not a skin for the main VDJ software.
geposted Sun 18 Sep 22 @ 1:53 pm
mg_1978PRO InfinityMember since 2008
hi, is there the “search” with touch keyboard for search a track title? thanks
geposted Mon 10 Oct 22 @ 1:28 pm
like this (denon Prime Go skin)
geposted Wed 12 Oct 22 @ 11:08 am
Ver 1.1 adds Light Theme in default Screen skin for your outdoor gigs.
The setting to choose between Dark (default) and Light themes is in Screen skin Settings->VIEW tab
geposted Sun 02 Apr 23 @ 7:37 pm
Day light mode?? Never mind, just saw the post up above.
Thanks
geposted Tue 06 Jun 23 @ 2:51 pm
Is there a Touch FX screen included like in the standalone mode? I can't seem to find it
If not, it would be fairy easy to add, I think?
Currently select FX On/Off on touch/release, and slider 1 and 2 on the X/Y values
geposted Tue 07 May 24 @ 7:20 am
Nothing in the xml.
I've added 2d sliders to other device screens [sc6000]. I don't see why it can't be done here. It's a little awkward to do remote edits without the HW, just down to the fact the device has hw buttons that call variables that change the skin.
It can be worked around, some cases it doesn't matter, it's just a bit more than usual skinning.
geposted Tue 07 May 24 @ 7:54 am
geposted Tue 07 May 24 @ 9:27 am
pulling onto my laptop screen, I can see where I'd put 2 * 2D sliders [replace; deck info & scratch wave] the question is how do I get to this new mode? screen space is at a premium,
call it via a HW button? which one?
nudge things on the skin a bit and fit a button between the 2 fx sections?
Weird choice to have pads 1-4 on the skin when there's HW buttons, I'd have gone for pads 5-8 but that's just me.
I've not seen the whole skin yet as I haven't looked at what variables are needed to call stuff.
geposted Tue 07 May 24 @ 11:20 am
