Discussion about Numark Mixstream Pro Screen
geposted Tue 26 Apr 22 @ 4:18 pm
Hello, I have downloaded the MixStream Pro skin to my PC, but it is not showing up in available options to use or apply this skin.
geposted Sun 08 May 22 @ 5:08 pm
It will be used automatically when you connect the Numark Mixstream Pro controller.
geposted Sun 08 May 22 @ 5:46 pm
Even after I connected it, it still didnt work for me
geposted Tue 17 May 22 @ 9:50 pm
You followed the instructions here:
https://www.virtualdj.com/manuals/hardware/numark/mixstreampro/setup.html
Both firmware and drivers are updated?
geposted Wed 18 May 22 @ 4:48 am
bonjour je cherche skin Numark NV svp
geposted Sat 11 Jun 22 @ 11:31 am
You can use any skin. The software does not need to look like the hardware in order to work.
geposted Sat 11 Jun 22 @ 2:07 pm
bad skins no work
geposted Mon 25 Jul 22 @ 8:35 am
Bigbutler wrote :
bad skins no work
It's not for the VDJ software - its for the screen on the Mixstream Pro
geposted Mon 25 Jul 22 @ 12:38 pm
Salut, Tu as trouvé depuis ?
geposted Tue 13 Sep 22 @ 6:45 pm
I have the same issue. Extensions indicate that I have the skin installed. It does not appear when I connect my controller. It is also not in the list of installed skins.
geposted Sun 18 Sep 22 @ 12:00 pm
It's not supposed to be visible there, as it's not a skin for the main VDJ software.
geposted Sun 18 Sep 22 @ 1:53 pm
hi, is there the “search” with touch keyboard for search a track title? thanks
geposted Mon 10 Oct 22 @ 1:28 pm
like this (denon Prime Go skin)
geposted Wed 12 Oct 22 @ 11:08 am
Ver 1.1 adds Light Theme in default Screen skin for your outdoor gigs.
The setting to choose between Dark (default) and Light themes is in Screen skin Settings->VIEW tab
geposted Sun 02 Apr 23 @ 7:37 pm
Day light mode?? Never mind, just saw the post up above.
Thanks
Thanks
geposted Tue 06 Jun 23 @ 2:51 pm
