Topic: Automix pane not showing?
geposted Tue 23 Aug 22 @ 1:28 pm
click or drag the tabs just below your arrow
geposted Tue 23 Aug 22 @ 2:00 pm
Geez, so simple, I spent a lot of time trying to get back the automix pane, thank you!!
Next, when playing with both decks in normal mode [with Automix turned off], the pitch control in both decks are moving on their own whenever I load songs into them, how/where can I disable this setting please? I have looked at all options in Settings but not noticing anything for this specifically?
geposted Tue 23 Aug 22 @ 2:17 pm
Check settings for BPM match, auto pitch etc. under automation settings like the following
autoBPMMatch
autoPitchLock
geposted Tue 23 Aug 22 @ 3:43 pm
geposted Tue 23 Aug 22 @ 4:13 pm
it's ok guys, this is now solved, I got the help from VDJ Support, seems I had to deselect the Autobpm option in "Deck options" in each deck's pane and not in Settings Panel.
geposted Tue 23 Aug 22 @ 10:23 pm
RaxianHome userMember since 2016
geposted Tue 08 Oct 24 @ 12:22 am
LIMOLPRO InfinityMember since 2003
Raxian wrote :
Having the same issue, but it's slightly different...
click on the folders Button or drag the vertical folders line to the right
geposted Tue 08 Oct 24 @ 9:06 am
