Hi, I have set this filter and it's great, but I don't understand why it starts in this position. This creates a big problem when you only want to use the midrange knob, because clearly the zero position does not match, and to be able to completely eliminate the voice and melody you have to first recover the position by turning the mid knob until 2 o'clock and only then do you can shut off all sound. is it possible to adjust this filter in the zero position as i believe it is supposed to be?
geposted Tue 01 Nov 22 @ 2:29 pm
UP :)
geposted Wed 16 Nov 22 @ 8:08 pm
Do you use a controller?
geposted Wed 16 Nov 22 @ 8:18 pm
yes (Numark NS7 III)
geposted Thu 17 Nov 22 @ 8:50 pm
