Topic: stems bugs/ usabitlity
- stems cant be computed via the vdj script
- with StemsRealtimeSeperation Enabled you can compute Stems for Streaming Services, but in the browser there is no option
- with StemsSavedStems: Manual it seems like it always saves the stems automatically.
geposted Mon 12 Dec 22 @ 11:28 am
- computed stems from streaming services can be found in the folder prepared, but only if you search for them with the keyboard
- can't find prepared Stems in Documents\Virtual DJ. Where are they located?
geposted Mon 12 Dec 22 @ 12:01 pm
They are right next to the audio tracks
geposted Mon 12 Dec 22 @ 12:37 pm
They do need to be downloaded first for the stems separation to have something to work on
Mine never does for real-time separation. Only if I prepare them - and then they of course need to be saved
geposted Mon 12 Dec 22 @ 12:40 pm
a feature was added now, so you can rightclick on the prepared stem an get to the folder where it's located.
thx a lot vdj team
geposted Tue 13 Dec 22 @ 10:54 am
yeah but this way you can't do it manually. even after loading the track.
adding the option (combined with download) to browser and vdj script would be awesome
geposted Tue 13 Dec 22 @ 11:00 am
It'd be very useful if you could extend samples (with silence) by increasing the length of a sample loop above the sample length.. (currently sample loop size is limited)
This would make playing sounds alternately possible, and grant new rythmic possibility with the sampler!
geposted Mon 02 Jan 23 @ 10:16 am
add to wishes forum, this is technical fixes.
geposted Mon 02 Jan 23 @ 10:19 am
Virtual DJ keeps setting "StemsFix: Don't use GPU"
since stems 2.0 i was able to turn it off again and stems worked fine, but now it keeps reenabling the option and won't get a single stems calculation done..
geposted Wed 04 Jan 23 @ 12:13 pm
What's your computer specs (Processor, RAM, GPU) ?
geposted Wed 04 Jan 23 @ 1:43 pm
why does this matter? if i uncheck the option and restart virtual dj, stems work fine..
geposted Wed 04 Jan 23 @ 3:06 pm
Is this issue relevant to the team? i'd love to not always search the settings after starting up vdj😅
geposted Tue 18 Apr 23 @ 8:59 pm
djcelPRO InfinityModeratorMember since 2004
Just to be sure, what do you consider an issue? Could you explain it again? Which build of VirtualDJ are you using? Can you describe your computer (cpu, graphic card, ram, ...)
geposted Wed 19 Apr 23 @ 4:56 am
i'm using and amd graphics card which works fine for stem creation. unfortunately VDJ changes my settings automatically so it wont use the gpu anymore.
geposted Sun 11 Jun 23 @ 3:59 pm
