i lost all my custom buttons with the update , how can i recover ?
geposted Tue 19 Dec 23 @ 8:29 am
This is not a problem of the Skin. The Custom Buttons are saved in the VirtualDJ/settings.xml on your systemdrive.
geposted Tue 19 Dec 23 @ 8:52 am
Hi Denny
i think a found a little issue on the jog info: when i load a track on a deck that is big ( lets say 120 minutes or more ) the time remaining on the jog does not display correct . like it does not have enough space to display all the digits
geposted Mon 25 Dec 23 @ 1:51 pm
Hi, Denny. I have been using the Prepare skin a lot and really love it. Is it possible to have a choice of Extra Windows be the center section of the standard layouts that has Mixer, Video, Scratch, Master?
Or, if you think of another way to give access to the Mixer section features that would be great.
Love, Live, Spin!
Riot
geposted Mon 25 Mar 24 @ 2:03 pm
Hi, Have to know your skins controller & actually project control are my fauvorite skins by far, more than 3 years almost been my default skin.
Well from last updates, not sure if are early updates.... i lost the return to last folder on the browser tree, temporally i will use a custom edit button to make this funtion.
I don´t tell you like a request or claim,
I see myself in debt, and it is a very small contribution to the excellent and hard work that you develop with these skins and that has given me so many good moments... Forever thank you and best wishes to you
ed:
return to last folder button donñt was located on browser tree, was at left in additional buttons...only this aclaration...thanks...
best regards
ed:
best regards
geposted Wed 03 Apr 24 @ 1:55 pm
in settings search for : previous
find option browserPreviousfoldersButton
enable it !
enable it !
geposted Wed 03 Apr 24 @ 2:26 pm
Thank you very much,
I'm embarrassed, I thought I knew each and every one of the settings options,
surely it will be relatively new, and I missed it, I'll have to look more carefully at the changuelogs,
thank you friend
thank you friend
geposted Wed 03 Apr 24 @ 9:01 pm
Version 1.0.9 - 2024-04-11
add - Linked Window (at the moment it doesn't refresh automatically VDJ Build 8019)
add - Mixer Window
change - add a Supporter
change - Custombar and Prelisten works seperate on the Browserwindow
change - some Customicons
add - Mixer Window
geposted Thu 11 Apr 24 @ 6:17 am
add - Mixer Window
add - Mixer Window
Thanks. This skin has so many features - some which are hidden, it should hv a vid attached. Keep up the good work.
geposted Fri 12 Apr 24 @ 3:00 am
Hey Dannyo, I like the features and customization offered in your skin.
If possible, I only request that you make the 'beat counter' adjustable, able to click on segments to match timing on other decks, assisting with syncing the beats between decks, similar to how one can manipulate the phrase sync for each deck.
It will help to keep the song structure tight when mixing.
Thank you
Thank you
geposted Sun 14 Apr 24 @ 8:42 pm
The ability to drag and drop tracks to the waveform may help some as well.
Thank you
Thank you
geposted Mon 15 Apr 24 @ 2:44 am
You mean the vertical Wave?
geposted Mon 15 Apr 24 @ 3:48 am
[quote=DennYo Beats]You mean the vertical Wave?[/quote
Yes.
Thanks
Yes.
Thanks
geposted Mon 15 Apr 24 @ 12:22 pm
Version 1.1.0 - 2024-05-06
bugfix - small position correctures
add - rightclick on the prelisten cog hide the prelisten player on top for 5 seconds (default Browser)
add - Song dropzone on vertical Waves
add - Song Info Window 2
add - FX BAR
add - alternative Song Info (Browser Sideview on bottom)
add - alternative Searchbar (Browser Sideview on bottom)
change - Browser (Sideview on bottom)
change - visual changes
change - add Customicon Stems Prepared (Browser)
add - FX BAR
geposted Mon 06 May 24 @ 3:03 am
Version 1.1.1 - 2024-05-18
bugfix - Mixer Window won't show on all Variations
geposted Sat 18 May 24 @ 3:03 am
Just wanted to reach out and say thank you for the work and skin you have provided, most useful and a pleasure to work with.
geposted Thu 30 May 24 @ 12:35 am
First: Thank You !
Where is the unload button ?
geposted Fri 31 May 24 @ 7:28 pm
I do appreciate the upgrades and updates to the skin. Thank you
geposted Sat 01 Jun 24 @ 10:05 pm
Version 1.1.2 - 2024-06-15
bugfix - Audio Mixer 2 Deck small
bugfix - FX Bar 2 Deck, 3 Slots, Deck 2
change - Linked Window works now
geposted Sat 15 Jun 24 @ 6:48 am
I can't find the vertical wave layout. Only options are off, top and bottom. Using latest build.
geposted Sat 24 Aug 24 @ 9:08 pm
