Forum: Addons
Topic: Project Control - Page: 6
Hi Dennyo. Is there a way to[...] [Edit: I answered my own question but will leave the accompanying thank you note]
Also, thanks for the tremendous (in amount and quality of) work you have put into this skin—discovering and customizing it was crucial in convincing me to switch to VDJ as my main performance software.
Hi, and thank you for this amazing skin.
I have a question on waveform order (scratch mode), with 4 decks.
I only have fixed options (1234, 3124 etc...), but I've seen once the order could swap.
Can't find back where to set this swap option.
Any idea where I can set the swap in order to have the wave stack reordering automatically to always have both waveform playing touching together ?
Thanks!
Fantastic work. Thanks
how to make one edit button change jog to video player . thanks
Hi,
test this :
toggle '@$jogvid_23'
Thanks!
The swapping Waves are only available on the swap Layouts.
Hi,
test this :
Hi
Work perfect. Thanks
i want another two edit button (from this skins knob adjust fx depth and fx beats of the selected effects. Thanks for your help
This is not a question about the skin.
Better you ask in the general forum.
https://www.virtualdj.com/forums/30/General_Discussion.html
Or in the script topic from Loco.
https://www.virtualdj.com/forums/223743/General_Discussion/Script_School.html
here a tip
Slider 1
Action effect_slider 1
Name `get_effect_slider_label 1`
Slider 2
Action effect_slider 2
Name `get_effect_slider_label 2`
Hi Dennyo.
Would you consider adding an option for a half-height, 23-button custom button bar? I like the flexibility the custom buttons allow but don't use even 23 extra buttons, let alone 46, and vertical space is at a premium in my setup. The A/B could be a single toggle rather than 2 discrete buttons.
I appreciate even simple skin changes take time but hopefully this would be a pretty light lift.
I continue to appreciate this skin on the whole—thanks as always.
I also noticed what may be a small bug. When '4 Cue Jump + _____' options are selected they display differently across the left and right decks. The left deck displays Jump/Target 3 and 4, and the right displays Jump/Target 1 and 2. This happens whether the cues in question are or are not set.
Is this a bug or is it working as intended and I'm missing something about how cuejumps are intended to be used?
