How do I turn off stems? It kept popping up every time I loaded a song during my last gig. I don’t want to remove stems. I just want to stop it from running. But I want to be able to turn it on when I need it.
geposted Mon 17 Apr 23 @ 4:49 pm
You will find it in the VirtualDJ options, Performance menu. It's the first option listed.
geposted Mon 17 Apr 23 @ 10:33 pm
Where is the option to turn stems off as I have the same issue coming up when loading a track whilst DJing out..
geposted Wed 13 Sep 23 @ 6:04 pm
search settings for
stemsRealtime
stemsRealtime
geposted Wed 13 Sep 23 @ 6:10 pm
It says prepared no option to change it...
Or stemsSavedStems
Manual which is ticked
Or automatic
Or stemsSavedStems
Or automatic
geposted Wed 13 Sep 23 @ 6:37 pm
Are you using an old build? I see the option "fully disabled" here
geposted Wed 13 Sep 23 @ 6:41 pm
Thank you, found it fully disabled...
geposted Wed 13 Sep 23 @ 7:07 pm
