Topic: virtual dj freezing windows with bsod
having a bit of a fight with virtual dj its detecting my two contollers the akai apckey25 and the apcmini
but trying to use them causes windows to freeze then throw a bsod its only when they are plugged in i bought the $300 license to be able to use them and i cant
geposted Sat 13 May 23 @ 1:40 am
Very irritating to say the least at least I can use my external mixer with multiple sound cards under that license but the issue with the controller is a bit rude
maybe this helps you
About Kernel Data Inpage Error
Kernel Data Inpage Error is a BSOD (Blue Screen of Death) error that indicates the kernel has requested data from the hard drive, but it couldn't read the data correctly or fast enough. It's typically caused by hardware issues (like faulty RAM), driver problems, or a damaged page file. This error may cause the loss of unsaved data or your PC to crash.
Do you have this bsod when only one controler is connected or is it only when both are connected?
You have bad memory or a bad hard drive.
