Hi,
I habe a brand new macook pro, M2 Max processor, 32GB memory and I'm getting an error when trying to use stems with DDJ-FLX10 controller
I'm getting an error stating 'stems engine error'
The log file says:
stems engine GPU failed. m1 error Fetching decryption key from server failed.
fallback to no stems seperation (GPU not available)
The log file says:
geposted Tue 04 Jul 23 @ 11:49 am
Could you write this command in Terminal and give us the result?
csrutil status
geposted Tue 04 Jul 23 @ 6:28 pm
It’s enabled, I already checked that after searching the forums.
I have ‘fixed’ the issue (possibly)
I turned wi-fi on and everything works again!
Does VDJ communicate to check something before enabling stems?
I have a full licence and was already logged in through the program too, so not sure why no internet would affect it?
Surely I don’t have to be connected to the internet at every gig to use stems?
nb I’ve not tried again yet without Wi-Fi turned on, will experiment again tomorrow
geposted Tue 04 Jul 23 @ 7:31 pm
Probably just needed to download some additional background files to enable the stems engine.
geposted Tue 04 Jul 23 @ 7:37 pm
