Hi, is there any way to order VST plugins by name?
It gets a bit chaotic if you have more than 10 plugins...
geposted Sat 13 Apr 24 @ 4:21 pm
Anyone?
geposted Fri 19 Apr 24 @ 6:00 pm
they aren't ordered by name already?
geposted Fri 19 Apr 24 @ 6:16 pm
Nope. Total chaos there is...
geposted Sat 20 Apr 24 @ 3:13 am
On my computer:
So we need to find what is specific on your computer. First can you take a screenshot like mine?
geposted Sat 20 Apr 24 @ 1:00 pm
geposted Sun 21 Apr 24 @ 5:16 pm
Anyone??
geposted 7 days ago @ 4:52 pm
2 assumptions to test:
- I see you have sub-folders => I am going to test on my computers
- the number of vst in the same folder => if you split in folders (vst3_1, vst3_2, ...), does it sort? Try with 5 vst , then 10, ...
Is there a vst with a special caracter in the name? Something that would make the sort fails
geposted 6 days ago @ 6:18 am
Okay, thank you for your suggestions! I will try!
BTW, the subfolders are necessary, because otherwise the Acustica Audio plugins won't work.
geposted 6 days ago @ 3:17 pm
