Topic: discussion about VirtualDJ 2026 Part 2 - Page: 1
Since the [NEWS] thread is locked, feel free to post here your first impressions or comments.
geposted Tue 17 Feb 26 @ 11:28 pm
Quick questions about the Variable BPM part of the update (great work btw!!! it's worked well for all the tracks I held back on manually gridding):
  • Is there any minimum requirements to use the new analysis? Is it based on Stem 1.0 or Stem 2.0 analysis requirements?
  • I noticed that the new analysis takes quite a bit of time on my M1 MacBook (like about 30+ seconds). Given all the new analysis potentially all happening upfront on song load (Lyrics, Stems and now new Beatgrid analysis), what kind of max load/average wait times are we expecting here, especially if we are trying to do things that are intensive (e.g. play video, livestream direct, broadcast to radio)? Also, would the analysis be piecemeal like stems analysis, so the track is usable with some subportion of the grid immediately (like the stem analysis), or will it have to be completely computed before use?
  • Is reanalyze "multi" deprecated now or is it an alias to reanalyze variable?
  • Is the BPM stabilizer based on the Master Deck BPM? Or it is based on the last BPM experienced in the display?
    My take on it was it would work with the current BPM displayed for the deck but it doesn't seem to work for me (I tried it with the deck by itself, and with the deck synced to another deck, with the bpm_stabilizer verb)
  • Is there a way to export the stabilized track?
    Basically a way to create a quantized edit for others, or for CDJ Export/standalone usage, which could prove very useful
- it's not "based on stems", it's a new AI, but the requirement to run it on GPU are the same as stems2.0
- it has to analyze all the song before giving the grid
- "multi-zones" is only used on songs >15mn
- BPM Stabilizer is not based on the other deck. you can activate it on a track that is loaded on a single deck. It will "lock" the current BPM of the variable track, so that the BPM stops to vary.
- yes it's coming
Thank you for the quick responses 🙏🏾..I'll try again with the bpm_stablize verb, I must have made a mistake somewhere in using it (the BPM varied in the display regardless when I tried).
Is there also going to be a way to batch-analyze files with it as well?
I'd like to just drop a set of tracks with varying BPMs in a list folder and let it go to work.
Also, given the requirement is the same as Stems 2.0, what will happen in the case of machines that do not meet its requirements?
the bpm stabilizer is accessed with the small lock icon that will appear near the bpm display if a track is set to variable BPM.
and about if a computer doesnt meet the requirement, same as stems2, it will then run the AI on the CPU (so it's slower, but still useable)
So I think that only displays with the default skin currently, so that's why I ended up using the verb mentioned.
Thanks, great feature!
One thing I noticed is that when setting an intro loop with variable BPM it locks to the correct beat, but doing the same with stabiliser enabled it moved the loop "off beat" per example 2 below:
Whoa… what amazing news to wake up to.
I’m really looking forward to the official release, but I do have one question.
Will this feature address the long-standing issue with cue point and loop inaccuracies on Rekordbox-imported tracks?
For those unfamiliar, this is a very frustrating problem that occurs when VDJ reads cue points and loops from Rekordbox. In about 99% of cases, they end up slightly misaligned by a few milliseconds compared to the original Rekordbox data.
With large Rekordbox libraries, it’s simply not realistic to manually correct every imported cue point and loop inside VDJ, which makes this issue even more critical.
Thanks VDJ FAM!
what is the limit of AI Visual Generations per month I'm on pro infinity licence
4 Generations on a 30 days rolling window
at least for the free ones, but you can buy some additional credits if needed or choose some from the provided libary
Very happy with this new feature in VDJ 🚀✨
Is there a way to identify tracks with multiple BPMs? When loaded on a deck and/or when displayed in browser?
(I'm thinking here of tracks with really different BPMs during the track, not those with irregular beat)
When seeking for "matching" tracks (based on key & BPM), is VDJ taking into account tracks containing a part matching the reference BPM?
I updated this morning to the latest early access (VDJ2026 Part 2) and I can’t find how to keep selecting the Shadertoy files I have downloaded in Plugins64 – Visualisations as a video source.
Now I only see: Slideshows, Visuals, Camera and Cover . Shadertoy no longer appears.
Has it been removed in this latest version, or am I doing something wrong?
EDIT: Sorry, I see they’ve been integrated into the new Visualisations folder and haven’t disappeared.
Thanks
Select Visuals - the Shaders are in there now.
Thank you Grovin, sorted!
Thanks
Tracks longer than 15min (which typically are recorded mixes etc) are automatically analyzed for multi-bpm (very different bpm). If you open the Bpm Editor you will see a (multi) indicator, and of course you will see the bpm changing on deck.
On the browser, you can also add the "Variable BPM" column. These files will be shown as "multi"
I made a thing!
Rather than having the tiny little squiggle (for variable tracks) with the lock above it, I put the word VARIABLE below the BPM, and clicking it locks the tempo & changes the text to LOCKED.
There's a new browser column. Variable BPM
It shows "yes" and "multi" depending on what BPM analysis has been made on the track
8%
