Topic: Atomix Compatible with Linux ?
Anyone Tried ?
geposted Tue 22 Jan 02 @ 8:21 am
alreaHome userMember since 2003
geposted Tue 22 Jan 02 @ 9:20 am
ikkeHome userMember since 2003
You can try to use WineX???
Greetz, ikke
geposted Tue 22 Jan 02 @ 4:59 pm
Wine is the windows emulator under linux.
Adrien
geposted Tue 22 Jan 02 @ 8:46 pm
While Wine (http://www.winehq.com/) does a reasonably good job on simple programs, I doubt whether it's quite up to running Atomix in a fast, reliable manner. When you need all the CPU power you can get, dedicated to the task of decoding MP3's, running under an 'emulator' is not going to help the cause any. If you really must run Linux for this purpose, then a dedicated Linux application is really the only way to go.
Cheers...
Swift
geposted Tue 22 Jan 02 @ 11:08 pm
