Topic: AutoMix Function
Hello Folk,
I have a problem using the auto mix function. spec of my system are shown below
1GHz Athlon
256 MB DRAM
16MB Voodoo Banshee Adapter
40 HDD
In built sound card
The problem I have got is when using the automix function, it appears to mix very slowly i.e the transfer from deck a to deck b is so slow. I cant imagine my system is slow. Is there anything I missing?
Ed
geposted Mon 11 Mar 02 @ 4:11 pm
Check the configurations. Mix length can vary from "no mix" to 30 seconds. Select the one that's best suited for your needs.
I don't think he would have the no mix option in 2.0 but you could turn the mix down like he said to 5s.
