Hi,
i've seen you have coded a lot of very nice effects.
Great work keep it up.
can you tell me is it possible to code a talkover- effect with sliders for the db settings so you can set the slowdown of the music and the time of doing this.(and the volume-up of the micro)
That would be very great if you could do that.
Thanks for an answer (and sorry for my bad english)
greetz
Janosch
greetz
Janosch
geposted Mon 18 Mar 02 @ 9:18 pm
shit! wrong forum. Could anybody please move it to the plugin forum?
geposted Mon 18 Mar 02 @ 9:20 pm
I think it is posible but it means that you must know how to control the line in or mic input yourself as atomixmp3 don't support these channels.
geposted Mon 18 Mar 02 @ 10:44 pm
What about a talkover button with a mic volume slider?
geposted Tue 19 Mar 02 @ 11:13 am
I think just an effect that cuts the volume on both decks while its applied would be great, but with the ability to set how low the volume is cut.
DJ Homeboy
DJ Homeboy
geposted Tue 19 Mar 02 @ 10:57 pm
