Topic: Beat matching
I really think there's something wrong with the "magic button", I've disabled the auto-pitch reset button but still I get many troubles with the beat matching.
geposted Tue 26 Mar 02 @ 11:19 pm
Could you explain us something more, please?
Is it possible that the beatmatch button is enabled.
The beat match button isn't disabled or so, it's just very weird that If you press the magic button the BPM still wrong is.
instead of 133 atomix makes 131 of it etc
could it be that the bpm it is trying to match is incorrect?
Do the peaks match each other still?
If so, then maybe you need to check the bpm or better still, set them manually.
Hope this helps
cheers =))
