Topic: Atomixmp3 and Windows Millennium ?
Hi,
does anybody run atomixmp3 with Windows ME.
My question is does Atomixmp3 work good with windows ME or not ?
I use it with windows XP and it works very good but on my second PC i wan't to install WinME because it's not the newest one.
Thanks for any comments!
greetz,
Janosch
geposted Thu 11 Apr 02 @ 1:27 pm
I've used Atomix on a machine with WinMe with no problems at all.
I use Win Me and no problem!
I use Win Me too, no problem so far.
D.
I have ME on my laptop that I take out to work. It works great.
For atomix I don't think you will have any troubles but personally, I find win millenium to be the worst os microsoft ever made. Stick with xp, 2000, or 98.
DJ Homeboy
I have winMe and I do have problems with skipping. It's running on a laptop. I had problems with v1.12 v2.0 and v2.1. I never had any problems with win98se on my old laptop.
Still, you pays your money and you take your choice... as they say.
Absoulutely no problems on my Win ME and granted it's not a great OS but it is definiteley better than 98
The above post is NOT true. You'd better install win98 on your computer. Indeed, WinXP is great but Millenium.......I don't know what OS it is but it is a very bad one. It kept crashing on my laptop.
Then second advice.......uh whatever "I use it with windows XP and it works very good but on my second PC i wan't to install WinME because it's not the newest one."
Just use WinXP!!
DJ Rogerzzz
