I'm planning on reformatting my Hard Disk Drive (H.D.D.) since I'm having lots of weird problems with it lately. I'm concern about reinstalling my recently purchased AtomixMP3 v2.1 afterward because I was given a unique serial# for it.
Does anyone have done this before (reformatting your drive)? Did you have any problems with the Atomix Serial#? Did you have to contact tech support before you did it?
What should I do? Please help.
Any information will be greatly appreciated.
Thanks to all in advance.
Johnny
Johnny
geposted Thu 29 Aug 02 @ 3:27 pm
What made is your HD?
geposted Thu 29 Aug 02 @ 3:39 pm
Waht make [sorry]
geposted Thu 29 Aug 02 @ 3:46 pm
What make is your hard drive is what phenryll was trying to say.
You should have kept your serial that was sent to you via e mail, if you did not keep it e mail service@atomixmp3.com from your regeistered e mail address and they will send it to you again.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Thu 29 Aug 02 @ 4:02 pm
Thanks Homeboy, you're my vocabulary complement ;)
geposted Thu 29 Aug 02 @ 4:13 pm
... or complement of vocabulary!?
llllollll
llllollll
geposted Thu 29 Aug 02 @ 4:20 pm
Thanks guys for the quick response.
My Hard Disk is a 20GB Western Digital Caviar W200. It's the main drive, where the OS is installed (C: drive) out of 4 H.D.Ds. that I have running in my computer. It's giving me a lot of problems. I haven't formatted it yet, though. I still have my AtomixMP3 Serial# safe and sound in one of the other drives and I was just curious if I was going to have problems reinstalling it after the format take place or if I change the drive with a new one.
Any suggestions?
Thanks again.
Any suggestions?
Thanks again.
geposted Thu 29 Aug 02 @ 4:43 pm
There are some maintenance utilities from West. digital which should correct your problem. A diagnostic test + correction and specific format command. Download them.
http://www.clubic.com/d/index.asp?o=2&marque=Western%20digital (the link is in French but the prg is in English)
geposted Thu 29 Aug 02 @ 5:02 pm
Honestly, I have gone through so many troubleshooting with this drive that I'm so tired of it. I just don't feel like dealing with it no more.
All my problems started when I installed Windows Me on it.
I had to uninstall it and reinstall Windows 98, because, honestly, WindowsMe Sucks big time. Of course, I had to reformat the drive to perform this task and since then I think the drive started dying.
Therefore, I'll just go ahead and change it with a new WD 40GB H.D.D. I had purchased a few weeks ago an never used so I can finally put an end to this painful feeling for good.
I thank you very much for your responses and hopefully I don't have to comeback crying that I cannot use my serial#.
Regards,
Johnny
Regards,
Johnny
geposted Thu 29 Aug 02 @ 5:42 pm
u might wana save your info on a disk if u have a CDR u can even save your atomixmp3 patch and program , and serial... after formating your disk you can reinstall it again ...
dj onepak
dj onepak
geposted Mon 02 Sep 02 @ 4:12 pm
i have virtual dj v 2.00 but lost the serial number. if someone has it,please let me know.thanx
geposted Thu 28 Jul 05 @ 5:28 pm
jjrosario
I will tell you what was told me a long time ago. After about 30 reformats I still had no problem reinstalling atomix.
Burn it to a disc along with the serial number.
The only time i had a problem was when my disc went missing ( stolen I think ) and had to get another download and serial number off the team here.
But I burned that one too, just in case.
Once you have it burned, you can reformat to your hearts content and it will always re-install just like any other program.
Hope this helps.
Raw-Bear
Hope this helps.
Raw-Bear
geposted Sat 30 Jul 05 @ 7:58 am
