Can anyone help, is it possible to record from Live streaming audio to your H/D?
Thank you
Thank you
geposted Sun 01 Sep 02 @ 6:55 pm
Certainly
I use creative recorder set to "what you hear" and it records fine...The only thing to remember is it records in wav format and this uses alot of disc space in the region of 600mb per hour...you can rip it to mp3 if you want to afterwards..
Its also worth closing any other applications that makes noises though for instance 'email alerts' etc as any sound including your mouse clicks will also be recorded !!
The sound quality will be dependant on the stream rate !!
hope this helps
STU
geposted Sun 01 Sep 02 @ 7:24 pm
Another program is Cd creator 5 platinum, use the spin doctor feature to record live streams and lines in on your pc.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sun 01 Sep 02 @ 10:09 pm
Thanks alot, where do I find this software?
geposted Tue 03 Sep 02 @ 8:49 pm
Well easy cd creator can be purchased or shared from p2p. Try kazaa, key words cd creator 5 platinum.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Tue 03 Sep 02 @ 10:38 pm
