Forum: VirtualDJ Skins
Topic: hmm, forgot 800x600?
Hi folks,
could anyone make all those real great and exciting skins in 800x600? On my music system I only use a 15" monitor, so the big skins can´t be shown correct.
Otherwise I had to upgrade to a 15" TFT. *g*
geposted Sun 24 Mar 02 @ 8:18 pm
That would be awesome, I've been bugging people in the forum to do this !
DJ Homeboy
I have talked to the Master Skin Maker (Jim) .... he said eventually he is going to work on that. I think that is important for laptop users and DJ's like me who multi-instance and need to see both windows and rhthym curves.
-- Dave --
OH ! If you are using a 17" monitor, A way around that is to set your resolution to 1152 x 864, when you use atomix. That way it comes out to almost the same size as when you use the 800 x 640 skins.
Well on my music system it´s only a 15". A skin for usage with an external mixer would be fine. So you don´t need the EQ, gain, volume and crossfader sliders and there will be more place for the effect, cue and loop knobs.
bueno
Hi,
after my next skin i will recreate a skin in 800x600.
I will start a Poll in a new topic wich one i should make in 800x600 because i can't make all skins in this resulution.
I work only with 1024x768 therefore the skins are made in this resulution.
greetz
Janosch
by the way. New skin is uploaded. Omnitronic1100S.
Have fun!
Yepp, cool skin! This one would be fine as a startup! :-))
