Forum: VirtualDJ Skins
Topic: changing colour of the visual mix bars?
I downloaded the CDJ1000 skin and think it's brilliant, but i find the red and blue colours of the visual mix bars difficult to decifer. especially when trying to beat match, when they go yellow! when the main deck is on top of the other, it's actually difficult to notice that they haveslightly gone off beat.
What i'd liek to do is change the skin slightly so that the selected deck is green and the other deck is red, without any middle colour (in this case yellow) so that when they are correctly matching beats, the green is over the red!
Hope this makes sense, ive looked at the XML file, but i'm not the worlds best when it comes to markup languages!
What do i need to edit?
geposted Fri 26 Apr 02 @ 7:58 pm
You need to add some text probably.
using the propers symbols before and after write something like this
color chan1="1" chan2="2" both="3"
in the rythm section of the xml
DJ Homeboy
go into the bitmap file, at the bottom it will look like there are three big rectangles, of solid color. just use something like photoshop, and with the selection tool, outline the entire colored rectangle (one at a time) and use the fill tool and fill it with the color you want. do that for the two desks.
Look in the xml file and find the "rhythm" tag (should be towards the top). inside it will be a tag for chan1, chan2 and both. then there are coordinates for each. say you want to change the color for channel 1, look at the coordinates specified after the chan1 tag. that corresponds to the upper left corner of the colored rectangle on the bitmap file. use the coords for chan 1 and chan 2 to make sure you change the right colored rectangle.
or you could just go change the colors, then switch the coords for chan 1 and chan 2.
now i haven't tried it, but maybe if you delete the "both" tag, then it won't change the color when one curve is overlaying the other.
i hope this made sense.. good luck
phatty720
dave
Just add the text that I have provided in the rythm area of the xml file following the code procedure with the proper symbols before and after the text. If you would like to e mail me the xml I will modify it for you. I have done this to almost all of the skins that I use cause I have gotten used to the red and green. My Icq # is 158207895.
DJ Homeboy
Editing the BMP for such a small change is uncalled for.. just use the text-based solution Homeboy posted.. it works wonders :)
thank boys, very much appreciated
