Forum: Old versions
Topic: Using headphones!
Hello,
I just started using atomixmp3's full version and have now access to modify the sound configuration and use my headphones. the problem is that i don't know how to hear the selected song in the headphones while the other song plays from the speaker. Is this possible?? what hardware requirements are needed? I use atomixmp3 in two computers, one has a SB Live! platinum with surround and a laptop that has a Yamaha AC-XG WDM Audio.
Thankyou
geposted Thu 18 Jul 02 @ 1:42 am
HomeboyPRO InfinitySupport ManagerMember since 2003
You must have the full version to use the sound configuration. Cracked versions do not allow the use of the sound configuration.
.:DJ Homeboy:.
geposted Thu 18 Jul 02 @ 2:11 am
I do have the complete version, i even have my serial number, the problem is i don't know how to use the headphones and speakers at the same time. How can i do this, hear the selected song on the headphones while the currente mix is playing on the speakers??
thankyou
geposted Fri 19 Jul 02 @ 9:25 pm
If you're a registered user, insert your serial in your profil, please. You will be a junior member, dus a full Atomix user. Then, we help you. @
geposted Fri 19 Jul 02 @ 9:40 pm
