Hi All
I am back with a new laptop I get a hum when I use the ac power and the line out on my laptop , but there is no hum when ac power is not used. Is there a fix for this? Other then
not useing the ac power.
Thanks All
Thanks All
geposted Sat 17 Jan 04 @ 3:50 am
is it a 3 prong plug?
Use a 2 prong adapter if so...
using an external hard drive?
geposted Sat 17 Jan 04 @ 7:53 am
What usb devices are plugged in also ? I got a bad hum from my cable modem through usb.
geposted Sat 17 Jan 04 @ 10:24 am
I will try the 2 prong adapter. Yes I use a external hard drive but it does the same with it or not.The only other usb device is my mouse.
geposted Sat 17 Jan 04 @ 10:41 pm
DJ Rick
The 2 prong adapter worked thanks. Do you know y this is?
geposted Sat 17 Jan 04 @ 10:51 pm
It's a grounding issue.
geposted Sun 18 Jan 04 @ 12:20 am
@audio000
The problem is called a "ground loop" and is caused by the power supply circuit design of the new laptop. I had the same issue with my new laptop which was the same HP brand as my previous laptop which never had the problem.
Here is the solution : http://www.xitel.com/product_gli.htm
I don't think it's a good idea to run on 2 prong without proper ground.
geposted Sun 18 Jan 04 @ 5:52 am
Thanks for the "solution" ;-)
I use the same filter "homemade" by a friend, and it's the best !
Coyote
Coyote
geposted Sun 18 Jan 04 @ 10:31 am
digijoc-Mele
I will try this to , it looks like this would help with someother
things to. Thank you
geposted Sun 18 Jan 04 @ 8:15 pm
hi coyote, can you tell us more details about the "home made" solution?
geposted Wed 22 Feb 06 @ 5:41 pm
