Forum: Music discussion
Topic: keyboard, mouse or both for mixing
docPRO InfinityMember since 2020
When you guys are mixing beat per minute, do you use the shortcuts on the keyboard, just the mouse or both?
geposted Mon 25 Feb 02 @ 7:25 pm
I use both. I use the mouse to push off the track and the keyboard to sync the beats and tweak the EQs
geposted Wed 27 Feb 02 @ 10:59 pm
Same for me.
geposted Fri 01 Mar 02 @ 12:44 pm
DJ CocoPRO InfinityMember since 2003
Same for me too!
geposted Fri 01 Mar 02 @ 9:44 pm
Me too!
geposted Sun 03 Mar 02 @ 11:22 pm
How do you tweak the eq's from the keyboard?
Much appreciated...
Superfly.
geposted Mon 04 Mar 02 @ 9:46 am
jokoHome userMember since 2004
I wish I knew how you guys are doing it. I also use both the keyboard and mouse but the shortcut to change the low, mid, and high's only adjust by halves. That's too much all at once. They should slide in small increments. Hopefully that will change with the next release.
geposted Tue 05 Mar 02 @ 12:21 am
HomeboyPRO InfinitySupport ManagerMember since 2003
I use my keyboard and mouse. To beat mix I set up the pitch on both players then hit esc. I have set this button up like this. Esc=play+beatmatch. It works like it use to in older versions of Atomix, I also use an external mixer with bass, mid and treble controls.
DJ Homeboy
geposted Thu 14 Mar 02 @ 8:01 pm
alholioHome userMember since 2001
I use keyboard for file searches (much quicker than a crate of vinyl!!)
Also use it for nudging and pitch shifting, starting, beat skip, flanger etc... x2 (one set of keys for each deck)
Mouse for not much!!
Mixer for EQ and levels, cuts etc.
At gigs I use a home-built hardware controller acting as a keyboard (although I can't do file searches when using this, cos I can't be bothered doing all the extra wiring ;)
Al
geposted Thu 14 Mar 02 @ 10:53 pm
Personally I use the keyboard when mixing with atomix.
As for vinyl, if it were easy, everyone would be doing it.
geposted Thu 14 Mar 02 @ 11:00 pm
nateHome userMember since 2001
You should check out the USB addon "pads" -- the one ive got has 20 definable buttons.. you define the buttons them label them, then set the shortcuts in atomixmp3... keep the pad close to your mouse, mixer, whereever your hands usually stay and set up everything on the pad.. then just leave the keyboard alone!
-nate
geposted Fri 15 Mar 02 @ 9:47 pm
ppramiPRO InfinityMember since 2003
I use keyboard and Mouse too!
geposted Mon 18 Mar 02 @ 6:30 am
MikeyHome userMember since 2001
hey a USB pad sounds interesting...i'll look for one, thanks!
geposted Thu 21 Mar 02 @ 12:25 pm
Mouse ? I using mouse for nothing.
geposted Mon 15 Dec 03 @ 1:38 pm
