Curious to see if anyone's using a mixer, or just the standard equipment. Been playing for a while now and lookin' to step up to the bigs, but want to know if anyone's using a mixer, and if so what kind, etc. I have a dual sound card setup (Soundblaster Audigy 5.1), headphones, receiver, amps (all the basic equip) but am curious whether or not the software will allow for accurate control if I hook up an external mixer. Any input is appreciated.
~~ Ricochet
~~ Ricochet
geposted Sat 13 Jul 02 @ 1:41 am
Check out www.djhomeboy.freewebspace.com
A list of my equipment.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sat 13 Jul 02 @ 1:51 am
My advice is that it is a good idea to have a quality mixer for your set. Not only does it look more professional, but it also allows you to upgrade to new equipment (CDs, TTs etc.) therefore it's a good idea to buy a mixer that has multiple line-ins if you can afford it.
geposted Sat 13 Jul 02 @ 2:47 am
Right now i am using a Numark DM2002x hooked up to my pioneer amp (just as impressionsDJ recommends for home use) ... i have that setup for home parties with friends. I am so friggin happy with this mixer. .. it rox !!
geposted Sat 13 Jul 02 @ 7:15 am
Thanks guys..What do you think about a controller-vs-mixer? I know that Numark has the "Official" Atomix controller, and was curious if it was worth maybe investing in? Or should I stick with the conventional mixer?
geposted Sat 13 Jul 02 @ 9:44 pm
The controller doesn't contain a mixer so it wouldn't hurt to get both.
geposted Sat 13 Jul 02 @ 10:31 pm
i posted some thoughs on actually going back to the software for mixing on the general forum, might be worth your while to read it. There are alot of nice mixers for under $75 right now, in fact musicians friend has a 2 channel berhinger for $39, at that price its sure worth trying, and definatly see how much you think it helps your skills before you make the investment in something more expensive
geposted Tue 16 Jul 02 @ 10:22 pm
I just bought a mixer and 2 turntables of JBsystem, and it's very professional. Only a little expensive...
Good luck buying your mixer!
geposted Mon 22 Jul 02 @ 9:13 pm
Definately get a mixer
I was in the same situation as you and decided to go for it and I'm one happy chap.
I just wrote a nice long message giving reasons why its good and why I chose my mixer the Pioneer DJM 300, but when I went to post it, I stupidly clicked on 'Reset post' without really thinking so I can't be stuffed typing it all again.
But contact me on nivek14@hotmail.com and I'll tell u how good it is and stuff. What too look for in a mixer and what not too.
Get a mixer, Kevin
nivek14@hotmail.com
Get a mixer, Kevin
nivek14@hotmail.com
geposted Sat 27 Jul 02 @ 8:57 pm
Can u use ne kind of mixer with vdj ??
geposted Wed 22 Mar 06 @ 10:59 am
jmez
yes any mixer will work with the full version of Virtual DJ. That option is disabled in the demo version.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Wed 22 Mar 06 @ 12:36 pm
