Hi,
I'm thinking of buying this software, but I like to be able to put in a playlist and let the computer AutoMix if I want. The setup allows beginning, first beat or cue for start and end, last beat or cue for end. I can't find a combination that either doesn't fade out to early or too late on most songs - is there any other "fine tune"?
geposted Sat 17 Aug 02 @ 8:43 pm
Just use cue 2 for end point but this requires that you set cue points at the end of each song.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sat 17 Aug 02 @ 9:07 pm
hello my name is jack.
i m looking for technical answer.
i m a dj used to play with turntables and i would like to be able to use mp3 mixer like automix because i m used to travel a lot and ...turntables are heavy.
i would like to know to know if automix is able to mix 2 songs for me.
for example if a song is runing on 150 bpm and the other one is waiting to be lauch...i would like to know if there s a "magic button " who match the second song to the first one...the two songs would be mixed on the right tempo.
in fact i just want to know if i have to adpt the tempo myself and mix the song or automix is able to do it for me?
thanks a lot.
please answer me.
jack
thanks a lot.
please answer me.
jack
geposted Mon 19 Aug 02 @ 3:36 pm
Yes there is a magic button that does that. You should download and try the demo.
Oui il y a un bouton "magic" qui synchronise automatiquement les bpms. Vous devriez telecharger et tester la demo.
Rendez-vous dans le forum francais pour plus de renseignements, ca sera plus simple !
geposted Mon 19 Aug 02 @ 5:02 pm
@Yelruc2: using cuepoint #1 as the startpoint of each track and cuepoint #2 as the fadeout-marker is probably the best solution if you want full control
@the other bloke: it's called Atomixmp3 so I would guess it's VERY capable of basic mixin, yes! :)
*mumbles something in the line of RTFM and slowly walks away*
geposted Mon 26 Aug 02 @ 9:17 am
hey necesito que me digan donde puedo conseguir una mezcladora en que pueda rayar ya que lo se hacer pero no se como hacerlo virtualmente
geposted Mon 23 Sep 02 @ 3:26 am
