Forum: Old versions
Topic: Y-Splitter doesnt work
Yes i have the full version. I only have one soundcard. I went to the local shop and bought a 7$ Y-splitter. Set it up, changed the thing in the sound setup. When monitoring, both songs play at the same time. One on the left speaker, and the right speaker plays the monitor. Same with the headphones. Is this how it is suposed to be? Because if it is, thats some crappy monitoring. Is this the best i can do without a 3d soundcard??
geposted Sun 15 Dec 02 @ 12:26 am
1. as you have bought atomix enter your serial number into you profile
2. you have bought the wrong type of splitter! i cant remember what sort you need but i'm sure homeboy will answere that :-)
You do need the full version. cracked or demo versions will not work. If you have the full version you need to buy a stereo headphone adapter that splits to rca, then run rca off the left channel for the left deck and rca of the right channel for the right deck.
