Greece pro v2,2 in 1024 res is allmost ready.
I done some changes:
1. Atomix logo is backround in mp3 browzer not in curves browzer.
2. Set que buttons is at the top of the deck screen.
3. Curves colors are red, blue and black.
All others the same like greece pro 2,1
Any other changing ideas?
geposted Thu 26 Dec 02 @ 10:36 pm
Is it going to have a Gain reset button? Also, would it possible to have both 1024 and 1280 versions of it for LCD screens?
geposted Thu 26 Dec 02 @ 11:50 pm
Gain reset is on in greece pro. Please don't ask me to write the xml file again for 1280 res. &=)
geposted Fri 27 Dec 02 @ 8:51 am
Ops sorry there is only level synch. But just double click on slider and slider reset. It works with all sliders. Volume, EQ, Crossfader, CrossEQ.
geposted Fri 27 Dec 02 @ 2:46 pm
I meant reset to 0db. And forget 1280. :) I will just sell my 17" LCD and buy a 15", sorry. :)
geposted Mon 30 Dec 02 @ 4:40 am
TO ABNORM:
Just double click on slider and slider reset to 0 db. It works with all sliders. Volume, EQ, Crossfader, CrossEQ.
geposted Mon 30 Dec 02 @ 9:38 am
will it have the five cue info?
geposted Mon 30 Dec 02 @ 5:52 pm
How about right click option for effects. Like when you right click its engaged the when you let go it is stopped. Not sure if greece pro already has this I use the original greece skin :)
geposted Mon 30 Dec 02 @ 7:33 pm
Will it have the five cue info?
YES all the five cue points displayed in decks. Just click the basic infos.
How about right click option for effects?
YES right click work in effects.
It is already in add-ons skins. Download it test it and i am waiting your coments.
geposted Mon 30 Dec 02 @ 8:30 pm
Mixalis, do you have the BMP layout of Greece Pro 2.2 with no text and empty buttons so we can customize it ourselves? Would be really nice.
geposted Sun 23 Feb 03 @ 8:43 pm
What is BMP layout of Greece Pro 2.2? I have greece pro 2,2 layout in corel9 file. I can send it to you if you want it.
geposted Fri 28 Feb 03 @ 12:19 pm
thank you
geposted Sun 13 Apr 03 @ 3:29 am
