Forum: Hardware Technical Support - Topic: problems installing free software??
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
problems installi...
Autor - Topic: problems installing free software?? -
acabucca
No license user
Posted Sat 31 Jan 04 @ 2:12 pm
Received by DJ Console today, eager to get started.
Not being a techie I am having problems installing VJ.
I am running XP home and on install it gets as far as loading up VJ fonts and freezes??
Does anyone have aby idea, is it an XP problem or software?
All the other free bundle stuff has been installed.
Superstom
Ultra-VIP Member
Posted Sat 31 Jan 04 @ 3:17 pm
First try to start VDJ without the DJ console attached. This should work ok, if your computer meets the minimal specs. Then shut down VDJ and connect the DJ console. The installing hardware box will appear. Wait until it is completely finished (box will disappear). Then start VDJ all should work ok then.
Good luck Ewout
acabucca
No license user
Posted Sat 31 Jan 04 @ 4:52 pm
Thanks for your help, but I have not even got as far as installing VDJ.
I am not sure if its an XP problem??
My system is pretty new and way over min spec.
Going mad now, I don't really want to use the new DJ software.
HELP
Coyote
Atomix Productions
Posted Sat 31 Jan 04 @ 6:25 pm
Disable your antivirus before installing..(and all program working in background)
Coyote
acabucca
No license user
Posted Sat 31 Jan 04 @ 8:27 pm
Thanks coyote.
Still not working, it only gets as far as installing fonts and freezes??
I have managed to get all the OTS and NewDJ, Storm installed but not this!!??
DJ Homeboy
Atomix Productions
Posted Sat 31 Jan 04 @ 8:55 pm
Have you ever downloaded a bad version from kazza or another p2p source ?
acabucca
No license user
Posted Sat 31 Jan 04 @ 9:23 pm
Thanks guys
I now have done a system recovery and after 2 hours it has installed!!!
Coyote
Atomix Productions
Posted Sat 31 Jan 04 @ 9:32 pm
Good news, thanks to XP and now, good mix :)
Coyote
