| Autor |
- Topic: Analog or digital EQs? - |
Posted Sun 01 Feb 04 @ 9:01 pm
I was wondering if the EQ knobs are controling VDJ or they simply analog and have only an influence on the output of the Hercules DJConsole. I would appreciate an answer. Thanks. |
Posted Sun 01 Feb 04 @ 9:36 pm
EQ knobs are controling VDJ. |
Posted Sun 01 Feb 04 @ 9:43 pm
Would you say that the latency of the EQ is tolerable? Is that possible to play with the EQ knobs and for instance, using the HIGH FREQ know and follow the high hat in trance music, or the latency is too long? |
Posted Fri 06 Feb 04 @ 1:34 pm
Hi
I am not a trance music specialist but the latency is
quite low and you can perform very quick moves with
all the console controls, they will be heard instantly in
the music.
Of course a pro DJ might tell you that it's wrong but
I mix techno and houre since 12 yrs on technics and
denon cd players, I have lots of fun with my DJ console.
HTH,
Hervé
