Hello, I upgraded to v108 and it does not recognize hercules controller. I selected it from the list as the sound card, no luck. Thanks
geposted Tue 03 Feb 04 @ 3:07 am
Did you check that the hercules DJ Console is enable in options (External Controler)?
geposted Tue 03 Feb 04 @ 9:18 am
also check the green alien (hercules settings)
the console has to be in DJ-mode. it will not work in ASIO mode (yet)
geposted Fri 06 Feb 04 @ 12:02 pm
Hi, yes I selected Hercules and DJ mode...any other suggestions would be greatly appreciated. The older version recognizes console but not ver 8
geposted Sat 07 Feb 04 @ 3:07 am
Hi,
Let me clarify that the upgraded ver 8 works fine, it's the full version 8 that has the problem. Thanks
geposted Fri 27 Feb 04 @ 6:36 pm
Completely remove all vdj versions (save your database before) and remove also all the console drivers, then reinstall. It should work this way.
geposted Fri 27 Feb 04 @ 10:39 pm
Will try that, thanks
geposted Mon 01 Mar 04 @ 4:09 am
