Forum: Old versions
Topic: VERSION 1.08 NOT RECOGNIZING CONTROLLER
nancybPRO InfinityMember since 2004
Hello, I upgraded to v108 and it does not recognize hercules controller. I selected it from the list as the sound card, no luck. Thanks
geposted Tue 03 Feb 04 @ 3:07 am
kaleoPRO InfinityMember since 2003
Did you check that the hercules DJ Console is enable in options (External Controler)?
geposted Tue 03 Feb 04 @ 9:18 am
also check the green alien (hercules settings)
the console has to be in DJ-mode. it will not work in ASIO mode (yet)
geposted Fri 06 Feb 04 @ 12:02 pm
Hi, yes I selected Hercules and DJ mode...any other suggestions would be greatly appreciated. The older version recognizes console but not ver 8
geposted Sat 07 Feb 04 @ 3:07 am
Hi,
Let me clarify that the upgraded ver 8 works fine, it's the full version 8 that has the problem. Thanks
geposted Fri 27 Feb 04 @ 6:36 pm
FruitPRO InfinityMember since 2003
Completely remove all vdj versions (save your database before) and remove also all the console drivers, then reinstall. It should work this way.
geposted Fri 27 Feb 04 @ 10:39 pm
Will try that, thanks
geposted Mon 01 Mar 04 @ 4:09 am
