all of my songs are clearly set up with destinct cue points. ie: break comes in, slows down etc...
the best feature about vdj is the ability to time the cues perfectly which i made charts for when i had cd players. ie: 44 sec slow, 1:59 out, etc...
the difference is, when im cueing up my songs, im timing it by seconds. ie: 4 seconds left until cue 3, 44 sec till cue 5, etc...
it would be nice to have a feature that gives the number of beats until a cue instead of time since all of the songs are automaticly measured by vdj.
thanks
thanks
geposted Mon 01 Aug 05 @ 9:52 pm
I'm down with this one
geposted Mon 01 Aug 05 @ 11:11 pm
I think this is actually possible with the actual skin engine. I would have to hava a look on developers section area.
geposted Tue 02 Aug 05 @ 2:46 am
lej78480, you are right.
This can be done in a skin by using the 'B' modifier on the '%tocueX' textzone. So, if you know where to look in the XML file anybody can modify any skin by adding the modifier to the textzone for displaying the time to X cue.
cstoll
cstoll
geposted Tue 02 Aug 05 @ 4:36 am
Right you have to modify a bit your .xml skin file. Have a try by doing a left or right click on the cue name areas; many skins have different display modes.
geposted Tue 16 Aug 05 @ 4:54 am
