Forum: Old versions
Topic: virtual DJ and cross fader
x-fragHome userMember since 2004
hi all,
this is my first post because i ve just bought this product :)
it looks pretty, but.....
why my cross fader doesnt work with virtual DJ program?
i ve alreasy set "advenced" in the DJ consol mixer...
where i wrong?
thank u all
geposted Tue 23 Mar 04 @ 11:29 pm
kaleoPRO InfinityMember since 2003
Hi, and welcome.
What do you mean by:
"why my cross fader doesnt work with virtual DJ program?"
Is it the only control of the console that don't work?
If it is, did you change something on the DJ Console Mapper?
Kaléo
geposted Wed 24 Mar 04 @ 7:54 am
hi n thank u,
exactly, it is the only control of the console that don t work, and i didnt touch anything in the console mapper!
i ve just downloaded and installed the last firmware(33) for dj console, and i've got directX 9.0b
i ve already tried to reinstall in order: 1)driver(the lastest), 2)virtualDJ, 3)update of virtualDJ (1.07) but, the cross fader
still doesnt work ...
where i wrong?
rob
geposted Thu 25 Mar 04 @ 7:17 am
I am affraid your problem is "Hercules DJ Console and cross fader".
Is it working with others software? (I don't think), so you may have a problem with your cross fader itself.
Firmware 33 seems to have some bugs, Firmware 34 should replace it soon.
In ever case, you should ask hercules support for more help, they may know this kind of behavior.
geposted Thu 25 Mar 04 @ 7:56 am
thank u for the fast answer :)
geposted Thu 25 Mar 04 @ 8:01 am
you're welcome :)
geposted Thu 25 Mar 04 @ 8:04 am
