Forum: Old versions
Topic: Pitch Blend
How do I get pitch - and pitch + blend
geposted Wed 24 Mar 04 @ 3:38 am
use keyboard shortcuts or another skin ;)
there are more ways to pitch bend:
If you don't have a controler or console, you can pitch bend by using your mouse, move your mouse to the active wave-form on top of the screen. hold down left mousebutton and slide it gentle left/right while playing.
if you have a controler (which is a better way to pitchbend) you can use the pitch up/down buttons, but also the jogdail is doing a fine job for pitching. Or.. you can use the keyboard.
as you can see there are many ways to pitch bend :]
theres a nice way to do it
if one beat is falling behind use ur mouse and right click on a faster speed momenterly the beat just jumps into place then u can use the +
ps : i'm kinda hammered so if any one understood what i just said could u please explain it coz i can do it rigft now
lol
dj smokey
Smokey, ehm.. could you say that again :-s ?
lol i was just trying to read what i posted and it sounds real funny
ok u have 2 songs playing ,.,,,,, one is falling behind in beat
put ur mouse over the pitch slider and RIGHT click somewhere with a faster speed just for a moment and let go ,,,, u can see that the beat will just jump into place with out having to nudge or pull the waveform with ur mouse ,,,,,,,, when u've done that u can now use the + to make the adjusment
with some practice its almost impossible to hear the diffrence
when u mix hip hop and r&b its a really good trick since the speed is never the same
i hope it makes more sence now
dj smokey
hehe it does, but i'm still glad that i have an external controler :p
well if u have an external controler you can still do the same thing just move the pitch slider all the way down for a sec and then bring it back i guess u get the point
any way
