Forum: Wishes and new features
Topic: Drop & Drag Samples into F1,F2,F3 etc
bmac16PRO InfinityMember since 2005
It would be great if VDJ had all samples listed in the window pane where your music files and other folders are listed so you can view them and drop them into the bucket you want (F1,F2,F3, etc) quickly.
Going into samples and having to open then scroll through all your samples and then load is very tedious. There should be a better way to get to your samples.
All thoughts would be appreciated
geposted Mon 05 Sep 05 @ 4:15 pm
djcelPRO InfinityModeratorMember since 2004
You can use the plugin "Samples Manager" to help you
geposted Mon 05 Sep 05 @ 10:42 pm
apopsisdjPRO InfinitySenior staffMember since 2003
Use shortcuts to quickly go to the samples page (and another to go back to the music page)
And/or use shortcuts to directly load samples. This is possible, take a look at keyboard commands.
It's not a good idea to have everything in the music browser. (confusing)
It has already the folders, the playlist, search, the suggestion folder...
Enough for a page.
geposted Tue 06 Sep 05 @ 2:55 am
