Hi,
I would like to see something most external mixers do offer. A more typical version of the headphone_mix function which gives the ability to fade between prelistening and the Mastersignal. Often it´s called "CUE/PGM Mix" - Traktor for example also offers this.
It would help a lot in situations where there´s no decent monitor setup, since it gives you the chance to backup into the headphones if you seem to loose the mix because of bad sound conditions.
Hope this gets considered for one of the next releases.
geposted Thu 08 Apr 04 @ 7:21 am
try the pioneer skin, it has additional faders in the upper-right corner
geposted Thu 08 Apr 04 @ 1:00 pm
This is not what he is looking for.
The headphone_mix feature does not allow to listen to your work on crossfader...
geposted Thu 08 Apr 04 @ 8:04 pm
But what is the need of this?
geposted Thu 08 Apr 04 @ 10:14 pm
It's just the way some DJs use to mix.
You have this feature on all real mixer so I think it's normal for users to ask for it.
Remember that not all users use an external mixer, and not all users are able to use a powerfull sound system... because of neighbors sometime.
That's why this feature should be a good thing.
geposted Fri 09 Apr 04 @ 7:17 am
To those at ATOMIX who decide what´s going to be realised, and what´s not: In the following thread there´s more users (and reasons) asking for this.
http://www.virtualdj.com/forum/display.html?topic=4142
geposted Fri 16 Apr 04 @ 6:33 pm
