i don't use it
djshadow
djshadow
geposted Tue 20 Apr 04 @ 5:33 am
I don't use the elastic mode too.
kheyo
kheyo
geposted Tue 20 Apr 04 @ 6:40 am
Rigid beatlock is the way to go. Elastic not.
geposted Tue 20 Apr 04 @ 7:57 am
You can don't use it at all, regards
Peter
Peter
geposted Tue 20 Apr 04 @ 10:10 pm
Gee, I wonder if they will keep it???I'm more of a rigid man myself.
geposted Wed 21 Apr 04 @ 2:02 am
I don't use the elastic beatlock
geposted Wed 21 Apr 04 @ 3:14 am
I never use the elastic beatlock. I prefer syncing my songs manually. In the worst cases, I use the rigid beatlock.
geposted Wed 21 Apr 04 @ 3:20 pm
i don't use the "elastic beatlock"
geposted Wed 21 Apr 04 @ 6:03 pm
Hi all,
You have My permission to remove this "odd" feature......and You may also sack the person who implemented it.
later,
Liam
later,
Liam
geposted Thu 22 Apr 04 @ 1:34 am
I'm really amazed how we all agree to this...
I never use beatlock at all, always sync manually keeping an eye to the visual waveforms (it really helps)
geposted Thu 22 Apr 04 @ 8:46 am
I definetley DO NOT use that, most of my friends dont either.
geposted Sat 24 Apr 04 @ 1:44 am
Rigid for me not elastic
geposted Sat 24 Apr 04 @ 9:07 am
All's i use is Sync, So yeah get rid of it.
geposted Sat 24 Apr 04 @ 3:06 pm
I do not use the "elastic" beatlock.
geposted Sun 25 Apr 04 @ 9:48 am
I never use beatlock at all...
By the way (a bit of topic) about that CGB or how is it spelled. Can there be an on/off switch made (if it isn't already)?
Regards
Regards
geposted Sun 25 Apr 04 @ 7:32 pm
i don't use it, i think it's a function not very useable for advanced Djs. It's better to have another options/functions instead of that :)
geposted Mon 26 Apr 04 @ 8:23 am
she dont use plastic
geposted Tue 27 Apr 04 @ 8:52 pm
Never used it
geposted Thu 29 Apr 04 @ 7:37 pm
I never use the elastic beatlock - In fact I don't use the beatlock feature at all !! I personally think it does not work properly.
geposted Mon 03 May 04 @ 11:25 pm
I said live it put it in the option section so if some body want it on they can put it on or trun it of,there is many things I don't like on some of the skins you all need to put them in option.
geposted Fri 07 May 04 @ 4:00 pm
