In order to implement the new features we want in 1.10, we may need to remove the "elastic" beatlock feature.
Before doing that, we'd like to check if any of you actually do use this feature?
geposted Sat 17 Apr 04 @ 2:00 pm
I do not use the elastic beatlock.
Kaléo.
Kaléo.
geposted Sat 17 Apr 04 @ 2:03 pm
I use rigid. It gives me the best approximation of the atomixmp3 beatlock (which in many cases is better) though I prefer virtual dj overall.
geposted Sat 17 Apr 04 @ 2:10 pm
althought it's a little off-topic, you can still use the right mouse button on the beatlock button to do the exact same "magic" action as in atomixmp3.
geposted Sat 17 Apr 04 @ 2:17 pm
Personally I don't value the beatlock feature, I just use play and sync, The beatlock really is like a backup in case the mix goes pear shaped, but with the sync feature and the on-screen display that's usually very rare with vdj, So no I wouldn't mind at all to see that feature disapear,
One idea of mine though..., seen as VDJ is designed to be used proffesionally( through choice obviously), and I know how VDJ is very stable, but....., should there be problems on the night in opening the software (sometimes a get an errorr and need to restart my computer), or a crash,
It would be good if VDJ had a back-up program, something with whole different files but effectively the same software, atomixmp3 for example, but to work antagonistically with VDJ ( bundled with vdj of course).
I don't know if i've made much sense here but I know what I mean, basically it would make VDJ super reliable, and you shouldn't have to pay out for other dj software as back up.
regards bagpuss,
regards bagpuss,
geposted Sat 17 Apr 04 @ 4:19 pm
I don't use the elastic beatlock.
geposted Sat 17 Apr 04 @ 4:23 pm
scrap it
geposted Sat 17 Apr 04 @ 4:58 pm
Rigid for me!
GnoedeL
GnoedeL
geposted Sat 17 Apr 04 @ 5:17 pm
It may disappear into the wastelands for me too.
Like rigid beatlock and rigid file/playlist view ;o)
geposted Sat 17 Apr 04 @ 7:15 pm
I do not use it
geposted Sat 17 Apr 04 @ 7:58 pm
I don't . But what might be good is to manually sync and when you get both songs in sync click on a button to actually lock it. I mean VDJ does the rest in terms of adjusting the BPM/Tempo of both songs(Like a manual beat lock).Some songs will be in sync initiallly and then start to veer off. That way we do not always have to nudge and in some cases, you can actually hear ths song drag when you "over" nudge and gives you more room to be more creative. Just a suggestion. I know I can make the suggsgtion in the new features forum but I might as well do it here since we have the ears now.
geposted Sat 17 Apr 04 @ 8:50 pm
I use elastic beatlock occasionally (for disco mixing) but it’s not an important option for me, I can mix my disco without beatlock on :-)
geposted Sat 17 Apr 04 @ 9:22 pm
Never use it...
geposted Sat 17 Apr 04 @ 9:40 pm
I dont use it! :)
geposted Sun 18 Apr 04 @ 12:51 am
I do not use the "elastic" beatlock.
Seb
Seb
geposted Sun 18 Apr 04 @ 12:32 pm
Kill it!
geposted Sun 18 Apr 04 @ 2:43 pm
geposted Sun 18 Apr 04 @ 3:07 pm
danydj
danydj
geposted Sun 18 Apr 04 @ 4:23 pm
Dj Dnk
Dj Dnk
geposted Sun 18 Apr 04 @ 5:02 pm
I never use the "elastic" beatlock.
Gwenn
Gwenn
geposted Sun 18 Apr 04 @ 6:08 pm
