Forum: Hardware Technical Support - Topic: Needles For Time Coded Vinyl
Please post here all questions or comments about the hardware supported natively or by MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
Needles For Time...
Autor - Topic: Needles For Time Coded Vinyl -
kidswirl
No license user
Posted Wed 07 Dec 05 @ 2:52 pm
Hey
I'm wondering if their are certain needles that are better for Time Coded Vinyl. I have Virtual DJ
and 2 Techs....i'm due for some new carts and haven't been able to find any info on this.
Are some better than others? Does it matter?
Thanks
DJ_whiteDVL
VIP Member
Posted Wed 07 Dec 05 @ 4:08 pm
Well it does matter a bit for the needles. Try to pick up needles with better tracking since the sound quality will matter very little.
Best Regards
DJ White Devil
djbambi
Experienced pro user
Posted Wed 07 Dec 05 @ 4:48 pm
I've tried several before settling on the industry standart Shure M44-7: they have a high-voltage output, incredible tracking, and especially you hardly hear the unwanted TCV noise (some cartridges actually produce a quite loud siren sound from the rubbing of the stylus on the TCV, that is even with your amp turned off, the physical contact of the stylus on the TCV is loud)
acw_dj
Senior Team
Posted Thu 08 Dec 05 @ 6:22 am
I use Sure SC35C to scratch and TCVs and Stanton 681 EEE II-S for my music vinyls.
The better is to buy your FULL license to get more info (and samples, effects, full access in the forums too) that is only available for Full VirtualDJ registered Users.
Good Luck!
apopsis
Ultra-VIP Member
Timecode expert
Posted Fri 09 Dec 05 @ 4:18 pm
3 recommendations from me,
depending on how important is to play regural vinyls vs TCV
Shure M44-7
-Industry standard for best tracking, but not so good sound quality.
Stanton 500AL
-best value for money, acceptable tracking and sound.
Shure Whitelabel
-expensive, good tracking best sound quality.
My choice now is M44-7, because of their skip resistance (and i dont play so much regular vinyls now). They have also a big advantage: very low record wear, very important if you play with 2 TCV's
JeremK
Senior Moderator
Posted Fri 09 Dec 05 @ 5:46 pm
Don't forget that whatever Needle you have for the TCVs, the Professional Version of VDJ will work much better than a cracked version.
(C)opyright Atomix Productions 2009
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
