wen i start a broadcast n sum of my friends try goin 2 tha site it shows in virtual dj 2 listenin and it dosnt work
geposted Fri 30 Dec 05 @ 1:46 am
this feature is not working in the demo, sorry
my brothers got the full version n wen i tried it no1 can get 2 tha site
geposted Fri 30 Dec 05 @ 1:49 am
your brother have the full version...:) hmm
well, anyways... depending on what version you have, you might have to find the correct ip yourself.
Only in 3.2 version the correct ip will show all correctly..
If your "brother" have an older version, then you have to change the ip reading at Virtual DJ to the real ip, and give that to your friends. Your real ip is here www.whatismyip.com
Hope that helps, and that you like the software, and hopefully buy a full licence for you soon :)
good luck with the broadcast
geposted Fri 30 Dec 05 @ 1:53 am
kk thanks alot
geposted Fri 30 Dec 05 @ 2:01 am
dj x-clusive, where u from n where u spin? I know a dj x-clusive...are u him?
geposted Tue 03 Jan 06 @ 2:47 am
