Dear Sir:
I buy atomix before. Now I saw Virtual Dj is good soft so I want buy it. but I try Virtual DJ I have question, before atomix set many song cue position on Atomix, how can copy to virtual DJ? If can not, I need use many time set cue position to Virtual DJ, It is big problem let me fear buy it, Can you answer me, Thank You.
geposted Sun 08 Jan 06 @ 9:15 am
in the earlier versions of VirtualDJ, i remember, that when you install VirtualDJ, before running the software, if you copy the Atomixmp3 Database in VirtualDJ folder, when running VDJ for the first time it creates a new database using the values from the atomix database.
Therefore, i cannot tell you if this feature still exists or not.
geposted Mon 09 Jan 06 @ 10:06 am
Thanks your answer.
but atomix and Vdj are differnet Cue database format,
copy to folder cannot work.
somebody can help me? I want change to VDJ.
geposted Mon 09 Jan 06 @ 1:04 pm
