Can you load it on more than one machine if you are the only person using it? If I decide to go digital as well as CD, I want to be able to have a backup laptop all ready to go. And I want to load it on my desktop to practice.
geposted Tue 10 Jan 06 @ 4:08 am
Simple answer...
Yes. You can load it on more than one computer AS LONG AS YOU ARE THE ONLY ONE USING THE PROGRAM !!!
The Support Team will let you know for sure.
Hope this helps
DJ CITY
Hope this helps
DJ CITY
geposted Tue 10 Jan 06 @ 6:46 am
According to the EULA, when you buy a license for vdj, it grants you (the user) use of the software. In other words, as long as you are the only user, you may install the software on as many machines as you like.
geposted Tue 10 Jan 06 @ 6:56 am
Thanks. That is what I needed to know. It will be only me, as a solo op.
geposted Tue 10 Jan 06 @ 7:05 am
