Topic: Mixing with one soundcard
Is it possible to mix with one sound card.. an use the headphone feature as well? I have about 5 outputs on my soundcard (integrated one) and when i choose the function in virtual dj an play both desks the same output which has d crossfader to it comes from all 3 output ports.
So if you kno how to do this plz reply...
geposted Sun 15 Jan 06 @ 10:11 am
PionaraPRO InfinityMember since 2004
Hey bigh_2k6...:o)
It is of course possible to mix with one soundcard, but this function is not available in the demo version. You can buy the program on the website http://www.virtualdj.com/purchase or if you have already bought it, update your profile with your serial number http://www.virtualdj.com/fusers/modifuser.html which will allow you access to all the features available.
When you have done this, you go into the 'Config' panel from the program and select whichever setup you are using. There are a number to choose from, including one soundcard to phones and speakers or if you have a mixer, you would select the 4.1 soundcard to mixer option. When you have selected the correct option for your setup, you should be able to mix very easily. You will also be able to cue your next track using your phones.
Hope this helps.
Cheers...keep spinnin'...:o)
P
geposted Sun 15 Jan 06 @ 3:11 pm
