Topic: Napster Global Database
Couple questions about the Napster Database. How come when i find and load a song on the global databse, it only loads about 30 seconds of the song and how come it doesn't show the BPM.
geposted Mon 16 Jan 06 @ 5:36 am
PionaraPRO InfinityMember since 2004
If you check your general settings and make sure that your max load is set to 'Always' this should solve the problem...unless it's something to do with the track itself??? Like maybe the type of track.
I know that if you use itunes, you need to burn them to cd and then re-rip them as an MP3 back to your pc. Not to say that this is the problem with Napster, but it might be something similar to this.
P
geposted Mon 16 Jan 06 @ 11:16 am
Dev staffHome userSenior staffMember since 2003
You need to have a valid napster subscription in order to play the full length of napster tracks.
Otherwise, it will only play 30" samples.
http://www.napster.com/ for more informations.
geposted Mon 16 Jan 06 @ 1:16 pm
Thanks, I kinda thought that was it.
geposted Mon 16 Jan 06 @ 4:45 pm
