How can i add my logo to appear on the output video screen. (Like a logo Bug)
geposted Tue 17 Jan 06 @ 7:52 am
DJ_Ossig
I think from reading other similair posts to this that you would have to write a video plugin that would show your logo...unless of course you just want it to show for a while, in which case you can just add text to the screen from the application itself.
You can check out this page http://www.virtualdj.com/addons/view.html?type=video%20effect for info on writing video plugins.
Hope this helps.
Cheers...and keep spinnin'...:o)
P
Hope this helps.
P
geposted Tue 17 Jan 06 @ 12:51 pm
This thread might also help:
http://www.virtualdj.com/forums/45206/Software_Technical_Support/Virtual_DJ.html
P
P
geposted Tue 17 Jan 06 @ 1:08 pm
you can also use a video editing program
then you can get your logo to do just about anything
my all-time favorite video editing program is VEGAS VIDEO
it use to be sonic foundry but sony bought them out
sony then jacked the price of all their software
great product though
also, lots of dj's use acid to remix songs
vdj rocks!!! but you use vdj to remix on the fly (live)
acid to remix like a painting -- keep adding stuff to it--multi track
anyway, good luck
anyway, good luck
geposted Tue 17 Jan 06 @ 8:05 pm
