Topic: virtual dj wont run
rite virtual dj wont run when i click the icon, it sayin xml plugin error then run time error how can i fix it
geposted Tue 17 Jan 06 @ 10:59 pm
Go to the VDJ Folder which is by default: c:/program files/virtualdj
Then go to "effects" folder and delete the file "plug_in.xml"
(if it doesn't work try to delete "BankSample.xml" in the same folder)
Remember if you have added any PLUGIN or SKIN since last time you could run the software right.
If not repaired with the solution that djcel says, maybe faster to uninstall/reinstall all again.
Im pretty sure that was the error i got when i installed VDJ, becuase my dad owns this computer and therefore has the administrator account, so he installed it to my account, and when i tried to run it it came up with the error, so i had to go into the fame settings, then enable mulitiple users (or somethign to that effect).. Becuase it was first installed to his account..
Sean
i have tried to delete it and it say its being use or something should i just un-install it and re-install the program but if i did would it be fixed?
delete the file when vdj is closed or start again your computer to avoid this message
