Topic: how do u output video to projectors etc?
drjustPRO InfinityMember since 2006
How does 1 output video from the VDJ spftwear to external monitors as well as Projectors for the crowd to view?
geposted Fri 20 Jan 06 @ 4:43 am
PionaraPRO InfinityMember since 2004
drjust
you would need a graphics card with a video out on it that you would run from your pc to a project/external monitor or whatever.
However, I'm not sure if this feature is available unless you have the full version, which you can get from here: http://www.virtualdj.com/purchase/ or, if you have the full version, please update your profile with your serial number:
http://www.virtualdj.com/fusers/modifuser.html
Incidentally, this thread might help: http://www.virtualdj.com/forums/12667/Software_Technical_Support/Video_Quick_guide_-_get_started_with_video_and_effects_with_VDJ_3_x.html
Cheers...and keep spinnin'...:o)
P
geposted Fri 20 Jan 06 @ 12:52 pm
