BE ADVISED !!!
This is a double post.
This is posted in the radio section as well as here.
Hey all...
How can I record my show while I broadcast?
I would like to record the show to The cpu and/or CD, just don't know how.
A little help wound be nice
Thanx
DJ CITY
Hey all...
Thanx
DJ CITY
geposted Sat 21 Jan 06 @ 9:29 pm
if you use a mixer you can use 2 outs. one to your speakers and the other to the soundcard's line in.
You will need another software to record (NOT VIRTUAL DJ) because VDJ will be busy broadcasting.
Hit record in the other software then start broadcasting. One thing from this is the fact that you will be taking up a lot of memory and your PC will be working much harder so your sound might not be what you'd enjoy it to be although definatelly test it out.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Sat 21 Jan 06 @ 11:46 pm
My Man W.D.
Thanx man
DJ CITY
Thanx man
DJ CITY
geposted Sun 22 Jan 06 @ 12:28 am
there is one more way, although it is risky if you dont want any hassels while mixing.. you could always use an audio recoreder like say Camtasia, or you could use Camtasias features to the full extent and record yourself visually doing the mix as well, not sure mate. Give it a look through though see if that works for you :)
-cheers
-cheers
geposted Sun 22 Jan 06 @ 2:56 pm
